![]() | Home > Puma (Tdci) > Air Filter !! |
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
Did you remove the hose that goes into the airbox first? It at least gives you a bit more freedoms movement.
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 ![]() ![]() ![]() |
Yeah took that off but the air con hose was the biggest problem totally limiting wiggle room. I ended up rolling the anti wear sleeve back on the air con hose for a bit of extra space.
I was being a bit careful with said aircon hose as it's on rigid metal fixings at each end and looked like it could be easily broken off the pump. The old filter was incredibly dirty for the miles the car has done, I guess picking up air behind the wheel isn't the cleanest option ! Jonno |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I fitted an ITG filter and it can be changed in minutes. Can't see your problem if you remove pipe and multiplug? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
I understand the difficulty, as I did it some time ago. My way to do it is to not put the filter in the box but first place it against the lid what make possible to engage the lid. then , you just have to engage the other side of the filter in the box and close it. sorry, I can understand that it isn't clear if somebody can explain it better ! Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
I'll try.
![]() Remove the multi plug for the MAF and the airtube then lift the top of the airbox off pushing the aircon pipe out of the way. Clean filter with vac and then refit into the airbox top before attempting to fit into box itself. Then holding the lid and filter away from you tilt it back/up at the engine end and slide the end nearest you gently under the wing. You'll have to push the airconpipe out of the way while you do this. As it goes further under the wing the filter will come into contact with the front of the box nearest the engine but just use your fingers to push the filter leaves back towards you and the filter will suddenly drop down with the lid into it's correct position. I've never had any prob using this method and had to show someone at the stealers how it should be done as they ruined a filter by not installing it correctly and water from off the wing soaked it. They did give me a new one though and I didn't charge them for the tutorial. ![]() AlanH. |
I don't know if its down to land rover tolerances, but there just isn't room under the wing top to engage the clips when the filter is in the airbox on mine.
Luckily there was just room to slide it in from the engine side once the clips were engaged. With the filter in first the clips on the lid are about 5 mm higher than their receiving holes in the lower section and no amount of pushing would get them in. This and the fact the aircon hose had to take a considerable amount of abuse makes me question the quality of the design a bit. Then again if certain bits and pieces were just a few mm in a different place it would have been a 2 minute job so I guess some are easier than others. Jono |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Be careful, even when the air con is not running the system is still under pressure.
A face full of air con gas is not nice, as I speak from experience. Excuse the spelling I`am better with spanners and wires. |
Yes that did concern me somewhat, the pipe from the pump has a fragile metal first few inches, so no doubt would easily break off.
Jonno |
