Home > Maintenance & Modifications > Larger front brake upgrade |
6 pot Member Since: 01 Apr 2010 Location: England Posts: 51 |
Yes it is a LS3. I am going to put the engine first after all I will be going from 120 ish BHP to 525 BHP so I think it will do for now. I am building bit of spare power into the drive train. The gear box is rated at 750 BHP and 750 lbft ( I think ). I will do a build thread as soon as I have something to post.
Cheers Rob |
15th Sep 2014 9:26am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
bay of e They come come up occasionally,usually go for around £100 new,think the cheapest I've seen one sold was £70 http://www.ebay.co.uk/itm/191329992944?_tr...EBIDX%3AIT Pov.spec,ftw. 2006, 110,TD5. |
15th Sep 2014 10:09pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Yeah, I spot them every now and again ... There was a pair that went for under £100 3-4 onths ago and I've always been annoyed at meself for not jumping on them when I had the chance!
Like you say though, they now seem to fetch well over £100 a side! |
16th Sep 2014 7:32am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2645 |
can we go back to the brakes, getting pm's from people now that the thread has seemed to moved onto the correct sizing of avatars.... a few people seem interested in them not just avatars.
16th Sep 2014 10:26am |
Give Rakeway a ring about them. They've been around a long time, so they aren't likely to mess people about. Seem the cheapest place to me, but just factor in the 18" wheels to! I personally dont think you need to uprate the brakes, even on a highly tuned TD5. Keep the OEM system bob on and they should handle it fine! It all also depends on driving style I would guess. You could also consider grooved uprated discs on a standard system (not britpart and not drilled ... there's some high spec alternatives out there!) and a nice set of pads to. For 6-Pot and the LS3 though, that's a completely different league that would require the brakes as I imagine that thing will hit 3 figures without much trouble! Not sure if you're running a different system though likeomg. Someone once said to me, the standard brakes can stop the truck, plus a 3-Ton trailer without troubles for normal driving. Special set-ups though, like the LS3, or special conditions, like tracking it, would possibly over work the standard system! Last edited by taazzukcb on 16th Sep 2014 11:04am. Edited 1 time in total |
16th Sep 2014 10:40am |
I plan to call rakeway and hopefully purchase them when I get into port tomorrow,
As for the wheel I'm already running 18" Click image to enlarge |
16th Sep 2014 10:44am |
128 MPH in 3rd |
16th Sep 2014 11:13am |
That from a Defender will be awesome! |
16th Sep 2014 11:16am |
Without wanting to go off topic again, what sort of rubber will you be running? I would assume AT's and MT's just wouldn't cope with a heavy foot from that motor!?
16th Sep 2014 11:17am |
My car when I do the brakes is getting the hybrid billet turbo I've towed my 2.8 ton boat, and the standard brakes were ok but my boats trailer is built for a heavier boat having real good brakes... But for my driving style I can easy warm up my brakes And 6pot, that's some strange gearing our vantage s would probably be high in the revs of 3rd if it even would do that speed in 3rd |
16th Sep 2014 11:24am |
I would hazard a guess that that's a theoretical maximum based on gearing.
Not sure what box ratios 6-Pot is planning on running. I would also hazard a guess, it probably wouldn't achieve quite those figure until it gets a blower as the aerodynamic properties of the Defender is about as good as a brick! The biggest obstacle is itself. So it'd need the extra clout of the Supercharger to get that down! Though saying that, I'm not sure of the tuning capacity that a stock LS3 has in it! likeomg, which Vantage S do you have and what box ratios does that run? |
16th Sep 2014 11:31am |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 |
Couple of LR LS3 videos to drool over
16th Sep 2014 12:01pm |
Awesome!!! Utterly awesome! |
16th Sep 2014 12:24pm |
Well that serves me right for relying on my brain now I am home the correct ish numbers are
1st 59 MPH @ 6500 RPM 2nd 80 3rd 112 4th 138 5th 164 6th 230 I think it will do 3rd and mayby 4th?. A nice quiet 75 to 80 MPH is what it will be doing most though. Not worked out by me but given to me by Rakeway. Cheers Rob |
16th Sep 2014 7:28pm |
