Home > Wheels & Tyres > What size bfg muds
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
What size bfg muds
So i am fairly settled on the bfg mud as a tyre selection but now confused about all the various sizes, 235, 255,265 blah bla blah.....on standard boosts what should i be buying?
Post #357622 13th Sep 2014 3:10pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
255/85 r16
Bit taller but a usable width He who dies with the most toys...wins!
Post #357628 13th Sep 2014 3:44pm
Jonno1968
Oh righto...I wrongly assumed 285 because more rubber on the mud? Sounds like im wrong again! Would 285 catch the wheelarch on lock?
Post #357637 13th Sep 2014 4:32pm
265 is the widest you can go without spacers / adjustments iirc.
235's on mine, can't complain.
Post #357638 13th Sep 2014 4:33pm
285s on mine. They will work with Boosts although a wider rim is recommended,and unless you fit 30mm spacers (or use wheels with 0 offset) your turning circle will be spectacular! You will also get crud all over the outside of the vehicle (inside too if the windows are open) unless you fit some form of mudflap adaptor. They look great, however!
Popular choices are 235/85, 265/75, both of which cause no issues, or 285/75. Any larger and you'll need suspension mods.
Post #357650 13th Sep 2014 6:50pm
Grouse
265 is the largest you can go without causing any issues, larger either mucks up your turning circle requiring spacers, which then results in steering shimmy, and horrible feedback through the steering when you hit bumps etc.
Personally having over 41 years experience of LR and RR's I would not go any larger than 265 or 255's at a push. 255's raise your gearing, and depending on your engine and power output can absolutely kill it - trust me I learned the hard way - larger diameter tyres can make 0-60 never happen...
Post #357664 13th Sep 2014 7:55pm
Jonno1968
Thanks for all the advice. Think i will go 265 by the sound of it is the safest maximum bet. Cheers.
Post #357676 13th Sep 2014 8:28pm
Rickydodah
In my opinion I would fit 30mm spacers also, I've not found that good quality hubcentric types introduce any steering problems but they do allow you to wind in the steering lock stops a fair amount giving you back a just about reasonable turning circle. 265/75 and 30mm spacers just allow the tyres to be covered by the bodywork. Thumbs Up
Post #357682 13th Sep 2014 8:43pm
camelman
I run 305s (305/70/16) on ET0 offset wheels and have a much better turning circle than standard as a result.
They are the same height as 255's but 50mm wider Smile
Motor chipped so no problem with 0-60 Laughing
Post #357766 14th Sep 2014 12:57pm
Cupboard
It's actually almost the opposite to that.
Width gives you floatation (which can be a good thing if that's what you want), contact *length* gives you traction. Therefore the taller the tyre the more traction, and if you've got the same area in contact with the ground the wider tyre will have less length on the ground.
Edit: 235/85 R16 is standard fit to Boosts, 255/85 is wider and taller, 265/75 is the about same height but wider, 285/75 is about the same height as a 255/85 but wider.
Post #357820 14th Sep 2014 5:13pm
K9F
camelman wrote:
I run 305s (305/70/16) on ET0 offset wheels and have a much better turning circle than standard as a result. They are the same height as 255's but 50mm wider Smile Motor chipped so no problem with 0-60 Laughing
A fellow forum member sent me a photo from your gallery as the recent wheel purchase of mine are exactly the same as yours. I too was considering 305's. For peace and quiet though I think I am leaning towards the 295 ATs instead of MTs?
Nice looking setup......
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #357853 14th Sep 2014 7:00pm
