Home > Tdi > Peeved Off
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Peeved Off
Thought i was going to be rebuilding my front axle not this weekend but next weekend but today my clutch decided to let go instead, master cylinder empty with fluid all over the floor and supposedly stuck in reverse ( son went to use it and all this happened ) lookerly it was on the drive when all this happened so i will go round and have a look and see whats up in the morning before i go to work Big Cry Big Cry Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #356925 9th Sep 2014 10:28pm
shaggydog
Be heartened, a clutch master cylinder is very easy to sort out and won't cost the earth.
Just make sure it is properly adjusted once rebuilt or you will have same issues I had Sad
Post #356928 9th Sep 2014 10:39pm
cornish rattler
Yeah i am just unsure why son is saying its stuck in reverse but really hoping its just the slave cylinder as was going to do all this when i do the galv chassis up re-build early next year Confused Graham
Post #356935 9th Sep 2014 11:23pm
cornish rattler
Its just the slave cyl that's gone so i will replace both the master and slave together ordering parts today so hopefully should get it done over the weekend oh and its not stuck in gear either Smile Graham
Post #357000 10th Sep 2014 10:54am
cornish rattler
On the bright side if the weather is crap over the weekend i can now get the 90 into the garage now Mr. Green Graham
Post #357150 10th Sep 2014 10:45pm
Tiger
Master is easy, if a bit time consuming.
Slave is a sod of a job!!! Getting that little plastic clip and the push rod behind it if it comes off is a total grrrrr of a job.
Gunsons bleed kit is highly recommended also!
http://www.halfords.com/motoring/garage-eq...-eezibleed
Post #357201 11th Sep 2014 10:10am
shaggydog
^^ +1 Thumbs Up
Post #357225 11th Sep 2014 11:46am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
take great care taking the slave of, slowly and gently, it is a mother of a job getting that rod and plastic clip back in. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #357226 11th Sep 2014 11:51am
cornish rattler
Sorry not been on for a bit ( internet prob's ) but sorted no, anyway sorted my clutch problem i had a couple of weeks ago and replaced both master and slave cylinder's and everything is ok again Thumbs Up Mr. Green Graham
Post #359675 23rd Sep 2014 10:37am
