Home > Maintenance & Modifications > 300tdi oil adapter for temp AND pressure
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
OK, I already have an oil pressure gauge, but now I'm planning on sticking an oil temp gauge as well, so I need another threaded hole. I currently have the standard T piece used for this common mod. I was wondering if you can get 4 way pieces. I have heard of the plates that go in front of the oil filter, if possible, I rather just have a 4 way piece than the adapter plate, if they exist. I am also trying to work out what thread sizes I need.
Without looking, from what I can gather, The oil pressure switch is 3/8" UNF. The oil pressure sender I have is 1/8" NPT. So the T will have a 3/8 UNF going into the filter housing (or wherever it goes near the filter) a 3/8 BSF for the warning switch, and then a 1/8 NPT for sender. So I'm after all that with another 1/8 hole for temp sender.
Does anyone know if one exists, and any links?
Thanks peeps. 1998 110 300Tdi White Hard Top
Post #357036 10th Sep 2014 2:10pm
