Home > Technical > Replacing Lower Door Frame |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5846 |
I did mine with the doors on, it might make it a bit more awkward for welding, but my excuse was, I didnt want the hassle of re-hanging the door on my own, and I was working outside with no cover.....
I'm pretty sure there are some pictures I took that are in my Gallery. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Sep 2014 10:41am |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
When mine were done we took the doors off as it is simpler for welding. You only need to peel the edges of the skin along the bottom and as high as you are going up, carefully.
Make sure you get the defender replacements, a lot on EBay are series sections which is different. YRM do good quality parts with plenty to go up the sides 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
9th Sep 2014 11:13am |
Knappster Member Since: 30 Aug 2014 Location: Stroud, Gloucestershire Posts: 43 |
Thanks for the advice. I'll probably have it replaced in situ with the doors on, just carefully peeling back the door skin.
I'll check out the YRM offerings too! Then a spot of wayoyling to hopefully stop the rust for a bit longer. Rich. |
9th Sep 2014 12:29pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Have a look here Knappster, the Bilt Hamber range gets amazing reviews in the classic car mags
http://www.bilthamber.com/cavity-waxes http://www.bilthamber.com/corrosion-treatments About to invest in some for the Td5 and Tomcat 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
9th Sep 2014 12:33pm |
Thanks for the recommendations, it's always helpful!
Rich. |
9th Sep 2014 12:38pm |
Here you go, step by step guide, he does some useful stuff, especially for when you do something for the first time
http://www.repairmylandrover.co.uk/defende...rnal-frame 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
9th Sep 2014 4:39pm |
That's great, thanks for the link.
Thanks all for the help and advice. Rich. |
9th Sep 2014 9:08pm |
