Home > Puma (Tdci) > Jerking when cold |
Portafilter Member Since: 08 Aug 2010 Location: Melbourne Posts: 27 |
if its a puma mine was caused by a faulty temperature sensor, cylinder head i think it was, not coolant.
7th Sep 2014 10:20am |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
Thnx Porta
Yes it's a 2010 Puma 110. Where abouts is this sensor? AlanH. |
8th Sep 2014 7:48am |
got it done at local garage, but pretty sure its top rear of cylinder head. they also loaded up new engine management software and ran heaps better. all up a couple of hundred bucks.
8th Sep 2014 12:17pm |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
I had erratic drive when cold and my dealer updated the ECU software and now is running fine |
8th Sep 2014 2:45pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
If you don't like jerking when cold, only do it when it's warm... 1998 110 300Tdi White Hard Top
8th Sep 2014 8:54pm |
Very droll......
My normal solution is to ignore it as it goes after a while but I'll see if the stealer can do it as the good mechanic we did have nearby is now too busy making money in the mines to bother with us. Cheers. AlanH. |
8th Sep 2014 11:03pm |
