Home > Td5 > Td5 plastic trims ... |
My 53 csw has all of these too
5th Sep 2014 6:16pm |
Mine has that as well, it's a 2002 110 built as a poverty spec but has abs and tc. I put it down to sound proofing so pedestrians can't hear you coming! Never mind the gap you can put your hands through where the bonnet meets the wingtops.
5th Sep 2014 6:55pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
Thanks both - I wonder what those bag things are for then ? I must admit to having half a mind to taking the underbody plastics and those pads out ... Other than trap junk I'm not sure I can see a purpose ?
My bonnet gap was such that my family kept telling me I'd left it open - and the engine was filthy, I imagine spray off the road hardly bothering the windscreen as it all went into the engine bay. I've adjusted it now though to the smallest gap possible . Much better |
5th Sep 2014 7:33pm |
The underbody "protection" has departed from my motor, in some ways it had a purpose, it did cut down a lot of the splash from puddles on the road getting on the alternator belt which cause a bit of slippage. On the other hand it makes servicing much easier, I do feel that excess heat does get away underneath a little easier when on the road plus it's easier to keep an eye out for leaks.
5th Sep 2014 8:11pm |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
Sorry to resurrect like this but does anyone have a photo or part number for this thing please? I'm trying to work out just how broken my own one is or whether I should just ditch it altogether!
3rd Sep 2017 3:44pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 933 |
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
4th Sep 2017 12:24pm |
Thank you very much!
Although at pushing £100 for some foam in a plastic bag I think I might just get rid of the remnants of it altogether! |
5th Sep 2017 10:12pm |
It does make things quieter... you could replace it with some closed cell foam just glue it to the back. Food for thought. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
5th Sep 2017 10:37pm |
