Home > Technical > Removing the steering wheel on a Puma
Eduardo
Hi there!
According the workshop manual it is necessary to use the special tool: Remover, Steering Wheel (PN 211-295) to take out the piece.
There is an alternative to take it out not using this tool?
Cheers! Eduardo
Post #355781 4th Sep 2014 10:23pm
landy andy
I just did it the old fashioned way. Loosen nut in center of wheel, leaving nut on, pulled wheel with knees and one hand, one good smack with hammer on centre shaft. Off it came, I think it may have even come off this truck without getting to the smack.
Andy
Post #355783 4th Sep 2014 10:30pm
K9F
Exactly the same as Landy Andy. Cannot emphasise enough to keep the centre nut on until the wheel is loose, alternative could be a nosebleed when it lets go and smacks you on the hooter. I loosened the nut and used a rubber mallet first removal.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #355800 5th Sep 2014 3:41am
Eduardo
Thanks guys Thumbs Up Eduardo
Post #355802 5th Sep 2014 4:22am
K9F
Eduardo you're very welcome, only remove the nut totally if you have one of these handy..... Rolling with laughter Thumbs Up
Post #355806 5th Sep 2014 6:32am
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
+1 for loosening first.
When I removed mine the first time without loosening, I also removed half my front tooth.
Post #355818 5th Sep 2014 7:11am
Eduardo
Rolling with laughter Laughing
Good advice and probably this special tool will be more acequible than the 211-295 Eduardo
Post #355907 5th Sep 2014 3:47pm
