Home > Technical > Just Bought a Disco rear Axle
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
I have bought and collected a discovery rear axle today person I bought it off said it is off a 3.9 V8 disco and it has the 300tdi style drive flange and the wires and sensors for the A.B.S. and as mine is a ( 1988 ) and doesn't have A.B.S. am I ok to just cut the wiring as close as I can to the sensors or do I need to remove the sensors altogether and if I buy or use my original 200tdi style drive flange off my original axle will I need a space between the drive flange and diff Confused
 Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #354630 30th Aug 2014 8:07pm
ickle
My old 200tdi / series 2 / coil sprung bitsa had an ABS front axle, just had the sensor wires cut off short and everything else worked as it should, I assume the rear is the same.
Keith
Post #354634 30th Aug 2014 8:14pm
cornish rattler
Nice one cheer's keith Thumbs Up Graham
Post #354639 30th Aug 2014 8:23pm
munch90
if I remember right the sensors just push in ,so when you got discs and hubs off if your rebuilding it just knock the sensors out
bit different then the front axle as they a wet sensor so you need to leave the sensor in or plug the hole , rears are dry just push in and there's a pick up ring on the back of disc you can leave off as well
Post #354641 30th Aug 2014 8:42pm
cornish rattler
Are right thanks for that, hopefully getting all the bits to re-build the disco axle and my front defender axle the front axle will be done whilst axle is on the car then when the disco axle is done we will swap the disco axle over Smile Graham
Post #354654 30th Aug 2014 11:13pm
jimbob7
ABS pick up rings on TD5's are £300 EACH,might be worth putting on eblag,as said,just take the sensors out. Pov.spec,ftw. 2006, 110,TD5.
Post #354718 31st Aug 2014 10:57am
cornish rattler
Will 300's fit TD5's Mr. Green Graham
Post #354905 1st Sep 2014 8:14am
cornish rattler
Note been on for a while ( internet problems ) anyway re-furbed the front axle last saturday inc new BP Teflon swivel kits, new CV joints, wheel bearings and new disc's and pads plus replaced my clutch master and slave cylinder as the slave cylinder was leaking then today me and son did a minor refurb on the disco rear axle we bought a couple of weeks ago and replaced the wheel bearings plus seals, and replaced the caliper's and disc's aswell then we gave it a lick of paint, so once we get the A frame ball joint, prop flang, and brake pipes made up we can fit it hopefully next month Very Happy Graham
Post #360524 27th Sep 2014 4:07pm
Fifth Horseman
Bit late finding this thread but the rear ABS ring is the same on all Disco, 1 Defenders and RR classic w/ABS (FTC1379)
Post #360533 27th Sep 2014 4:41pm
cornish rattler
This is the axle now and nearly ready for fitting just need a couple of bits and pieces to swap it over in a couple of weeks time Very Happy
 Graham
Post #360957 29th Sep 2014 12:21pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Just continue with pictures. I have the same idea for our 130 - out with the salisbury, in with rover axle from D1, with Aschroft locker and 1:3,8 HD gears. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #360984 29th Sep 2014 2:23pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
thats very shiny, what did you do for brake pipes?
Post #381381 23rd Dec 2014 7:03pm
