![]() | Home > Td5 > Engine temp never exceeds ~35%? |
You can get the typical Land Rover answer to this......."They're all like that Sir". When I start mine from cold it will go from rest to about the 10am position and after a few miles will settle around the 11am position and stay there. If it does go to the red it is accompanied with the ecu sticking the engine in limp mode,
I've given it some serious towing uphill with a Nanocom plugged in and the temperature sits at around 85 to 90'C and with a prolonged load can creep up to 115'C without the needle moving even though you can sense the engine getting warm. When you get over the 115'C mine is fast approaching the point where the ecu will say enough's enough and put it into limp mode with the guage showing hot, not a lot of warning and a bit of a pain in the ar*e. It seems to be the norm and it makes me wonder whether the temp guage is picking up its signal from the radiator and the ecu is from a more business point such as the block. |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 340 ![]() ![]() ![]() |
Ok, roger that! I'm glad there is no reason to worry. At least, not about something being wrong with my engine / EGR / etc.. The design of the temp guage is disconcerting though!
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Mine is the same even on the hottest days, the temperature gauge seems to have 3 positions,Cold,Normal and too late !
I thought the idea of a temperature gauge was to let you know when the temperature was rising so you can back off and stop it getting critical not to keep you in the dark until it goes into limp mode ! 2005 Td5 90 XS Steve |
