Home > Puma (Tdci) > 20k and the faults so far....
Plodster
2011 Defender 110 Puma 2.4 HT Baltic Blue
So my 2.2 90 HT has reached 20k this month and I'd like to say it's been trouble-free, but I would be lying!
Replaced and repaired so far:
EGR
Rear callipers
PAS pump & belt tensioner
Clutch
Gearbox selector bushes
Gear stick and selector
Windscreen seal
Bulkhead seal
Coolant pressure cap
Swivel sea
Handbrake cable tensioner
Door seals
Window mechanism
Door locks
Plus of course the obligatory intercooler pipe recalls and ECU updates!
Suspect the next item will be DPF related given the current issues and wondering what the next 20k will bring! Hmmmm, thats not mud....
Current:
Defender 110 HD Utility (Special Vehicles)
Freelander 2 HSE
BMW E23 735i
Ex:
2013 Defender 90 2.2
1998 Discovery 300TDi
1972 Series II 2.25
1980 Series III 2.25
Post #352421 18th Aug 2014 8:40pm
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Oh my god. That's awful. Yours must have been built on a Friday afternoon!
Post #352426 18th Aug 2014 9:15pm
munch90
why were the calipers replaced with less then 20k
Post #352433 18th Aug 2014 9:37pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Had mine three years, covered 66k miles, following parts replaced:
Wiper blades
Side light bulb
A wheel bearing
Post #352444 18th Aug 2014 11:34pm
ZeDefender
It really is horrible how inconsistent they are with build "quality" - never ceases to amaze me. I wonder if the new one will be any better... Tell someone you love them today because life is short.
Post #352447 19th Aug 2014 5:06am
aage
Iceland 2011 Defender 110 Puma 2.4 DCPU Alpine White
Mine at 18.000 miles
My 2011 at 17.000 miles
Failures so far :
One wheel bearing seal ( changed it myself , 1hr job )
Driver seat foam ( fixed it myself )
One shock rubber bushing ( Lower rear , fixed it myself 5min Job )
Nothing else and I love this car Wink. http://www.defender2.net/gallery/index.php?cat=13451
Post #352451 19th Aug 2014 6:26am
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Had mine a while....replaced nothing...not sure i would notice anything wrong. Its a noisey bone shaking ride...how would i know? Smile
Post #352452 19th Aug 2014 6:35am
Happyoldgit
All down to not being built by robots but on a production line manned by humans using processes rhat have changed little over the decades. Steve.
http://forums.lr4x4.com
Post #352459 19th Aug 2014 7:10am
Plodster
And we still love them! Hmmmm, thats not mud....
Current:
Freelander 2 HSE
BMW E23 735i
Ex:
1972 Series II 2.25
Post #352466 19th Aug 2014 8:10am
caterham6
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Its only "Money" Mr. Green
Post #352471 19th Aug 2014 9:01am
Plodster
That's what the warranty is for! Hmmmm, thats not mud....
Current:
Freelander 2 HSE
BMW E23 735i
Ex:
1972 Series II 2.25
Post #352473 19th Aug 2014 9:06am
newhue
Australia
Plodster, look at it like at least your dealer is willing to do such work. It would not surprise me dealers use warranty to keep the workshop turning when times are quiet, or they have a special like to you and are keen to have your truck 100%. It could just be being hand made you and I received cars made on a day no one was interested. I was amazed how much stuff went into mine in the first 100 000. ECU, transfer box, EGR, starter motor, an ignition, two immobilisers, key barrel, couple clutches, couple door locks, door rubbers, suspension rubbers, gear box robbers, floor matt, and a fair bit more just cant recall really. Odly enough after the 3 years was up it's been trouble free seemingly having been finished off by the dealer and reliable at last.
It can be frustrating, but as long as you have a loan car, who cares what LR do to it under warranty. I'm pretty confident there was no profit left on mine for them. I didn't ever drive a hard line, just noticed stuff and they went nuts. Still I'll probably by another LR as I am impressed with the warranty. Other marks have similar issues, but you do hear getting warranty is like blood from a stone. At least we find it amusing to some degree. My Defender and travels
Post #352482 19th Aug 2014 10:21am
This thread made me think about mine, a 2007 2.4 110 now at 7 years and 150k miles:-
Parts replaced due to failures/malfunctions-
Front diff
Front halfshafts and drive flanges
ROS hub oil seal
Rear halfshafts and drive flanges (twice)
Clutch assy (now on fourth clutch)
Rear propshaft UJs
Transfer box rear oil seal and handbrake shoes (twice)
Transfer box
Dip/indicator switch
Light switch
Wiper park switch
Windscreen (due to large rock, not LR's fault!)
Front disks and calipers (wear and tear, not really a defect)
Volume control valve
Fuel tank breather
Driver side seat base foam
Sump pan
Intercooler pipe
In addition it has had regular service parts and consumables such as brake pads. It is on its second set of tyres (I love BFG Muds, 100k miles from a set)!
On the "to do" list at the moment: the ROS brake is dragging and so I probably need new rear calipers, the rear disks are about due for replacement, the weather strips on all four doors need replacing and the radiator is weeping and needs replacement.
Is this bad? I don't really think so. The vehicle works hard and has done a high mileage, and I love it to bits (at least most of the time). It still puts a smile on my face.
By comparison at this age and mileage my Disco 2 had had one clutch changed (due to DMF judder not wear) and that was all.
(Editted to add a few things I'd forgotten).
Post #352488 19th Aug 2014 11:16am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
I guess you don't name it right. These are all not faults, it is just socializing and selecting it's driver by getting you used to repair, care and maintenance. Would you like a car, which accepts the worst lunatic driving it? Never forget: cars have owner, Landrover have field service personnel.
Post #352723 20th Aug 2014 2:27pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Replaced parts
Mine 2009 MY and has done 51k miles. Replaced following.
*front differential
*front differential oil seal
*clutch, pressure plate
*Four Injector bottom washers
*front and rear brake pads
*front wipers.
*intercooler hose
It's not a Toyota. It's a Landrover so no surprise. But I am enjoying it!
Post #352748 20th Aug 2014 5:17pm
