- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
ZeDefender
Cleaning injectors with a diesel purge | |
I want to give my (probably filthy) injectors a really good flushing so I'm considering a diesel purge (as well as additive). Normally one would disconnect the rail feed and return lines and use a couple of tubes to go to the jar of purging liquid (e.g. Liqui Moly or Wynns), running the engine on it for a few minutes.
However, since I'm changing the fuel filter anyway, wouldn't it be easier to fill the new one with purge instead of diesel and run it through the fuel system that way?
I'm suspect I'm missing some really obvious problem - hopefully someone can point out what it is
Matt Tell someone you love them today because life is short.
17th Aug 2014 7:51am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
