Home > Technical > Front prop shaft part number |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 |
My VIN is SALLDVAD7AA29*****, according to Rimmer Brothers FRC5566P it is a Bearmach front prop for mine.
Hope they goy it right cue i've just bought one |
16th Aug 2014 5:00pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5771 |
Buy a bailey Morris prop direct from manufacturer, then never worry about it.
Andy |
16th Aug 2014 7:53pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 327 |
Parts book I've got shows for the 2.5 petrol/diesel front propshaft FRC5566 to VIN 252442 and FRC8390 from VIN 252443.
However on microcat the breakpoint is at VIN 252578. Either way the change was in 1986/7 That said, the flanges on both the axle and transfer box don't change and the difference between the two 'shafts seems to be the construction of the main tube, sliding joint and the size of the u/j's, all info i can find says the length of the two types is the same (650mm). In summary, either should fit but IIRC the later type has larger (better) u/j's |
16th Aug 2014 8:16pm |
