Not today but a couple of days ago, packed up to come home after 12 days in a tent near Bala.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
What did you replace your bushes with? Standard or poly? I've already done my shockers all around but got the steering damper to go. Got a lot to do at the moment so it's not a priority but I will do it sometime. I've got a new damper to so should be just a swap, trouble is I've got a steering guard so that'll take extra time. |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 ![]() ![]() ![]() |
I replaced them with poly bushes. As for the damper, I've got a steering guard too. It's slightly more awkward, but still quite accessible.
Jon. |
Was it actual Polybushes by zany chance?
On mine the two bushes on the threaded end are a bit larger than the original rubber bushes, were yours the same? |
Oh no sorry, the steering damper ones were just standard. Yes the top bushes are quite a bit thicker, but they compress.
Jon. |
Here they are:
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The push fit end is fine and in the last photo as you can see is fitted already is just the threaded end bushes seem a bit larger. I expect they are probably meant to be though I'd have though and as you say do get compressed. These bushes are really good though from the drive quality on the shocks, very impressed. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
Changed front and rear diff oil - old oil dark brown colour.... 1999 Defender TD5 110
Yes, mine were similar, but they do compress when tightened. Jon. |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
Ahead of our wedding anniversary on Monday, I made a secret shop while SWMBO is at work today to get the ingredients for a Nor'n Ireland pasty supper.
You cannot get these anywhere here, so I have been finding a recipe this week. It is the one thing SWMBO misses more than anything, so I thought I would give it a try. Now made them, just hope they get the ![]() |
As far as pastie suppers are concerned, I'd class myself as a bit of a connoisseur. If you want to post me a few, I'll be more than happy to give my considered opinion.
![]() Jon. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
Just in from swapping over the rear o/s door harness
![]() ![]() Unfortunately while removing door card very carefully the fir tree fixing top left broke away from the door card (base and all)..... Upon inspection it's not the first time ifs been glued back together.......i can only assume it was while the rear by LR was under taken 6 months ago....proper repair this time (replacement not a bit of solder).... Just waiting for glue to dry before it goes back on. |
Went to Wilton supercar show .. Had a look at all sorts of exotica and the twisted defender with a red leather interiour
The Aston Martin 4 door estate was interesting too |
Defender LAF Member Since: 27 Jan 2014 Location: Dartmoor Posts: 14 ![]() ![]() ![]() |
Got the old 80 out for a photo shoot, then off for a lil drive
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge. ![]() Click image to enlarge |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
Great pics Defender LAF!
![]() My Defender has finally set off on its second sea leg from Australia. Left Singapore this morning, bound for Felixstowe on 2nd September. Miss it A LOT and can't wait to have it back, red dust and all! ![]() Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
