Home > In Car Electronics > Blue Sea Relay activation Voltage |
I assume you have seen this? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
10th Aug 2014 6:57am |
just read on bluesea website the voltage has to be 13 volts for 2 mins to connect and batterys have to drop to 12.75 volts for 30 secs to disconnect
10th Aug 2014 8:51am |
Riyo Member Since: 26 Jun 2014 Location: Aberdeen Posts: 89 |
thanks for the replies, i measured the battery voltages and they are 12.87 and 13v with the engine off... i guess i need some load on the battery then to bring the voltage down enough for the relay to disconnect the batteries.
10th Aug 2014 11:19am |
