Home > In Car Electronics > How much for a switch |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
which switch! What do you want the switch to control?
9th Aug 2014 6:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20552 |
Aux lights one I'd imagine?
LR prices vary greatly, a centre dash used to cost about £60 now £200. Last edited by custom90 on 9th Aug 2014 6:33pm. Edited 1 time in total |
9th Aug 2014 6:33pm |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Two spots on the front 100w each. I bought a wiring loom and relay with switch already wired up. One problem is imdont know which is the earth coming out the back of the lamps...white or black. .?
Black should be the earth just by it's colour.
9th Aug 2014 6:34pm |
I thought that but was only 60% sure! Thanks.
9th Aug 2014 6:36pm |
usually its black for earth, use a power probe to determine it though or just connect to a 12 V supply to determine which is earth, cant do any damage if you have a fuse fitted.
9th Aug 2014 6:37pm |
Unless they are LED which from your description I don't think they are then it doesn't matter.
Only LED are polarity sensitive. Makes sense though to get it correct though, quality of work completed and all that. |
9th Aug 2014 6:38pm |
a lot of lights use white as earth , like towing electrics
certainly a lot of led lights do use white as earth but I would guess spots would use black , but only a guess depends a lot where there made |
9th Aug 2014 6:40pm |
9th Aug 2014 6:42pm |
