![]() | Home > Maintenance & Modifications > BAS REMAP, INTERCOOLER AND ALIVE EXHAUST |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Do you have any photos of the exhaust?
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 ![]() ![]() ![]() |
indeed sir, i have
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
Very nice.
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 ![]() ![]() |
The out of whack intercooler.
Did you seat the cooler properly on its lower rubber mounts. Initially I thought things didn't line up, and after the second fit up realised that one rubber foot was not in it position so hence the welded pins on the middle of the cooler didn't line up. So after a third fit it all went in exactly where it should. Open up that air box a bit and it also seems to make it happy. Can only talk via seat of the pants experience, and it is minimal, could even be the placebo effect, but it seems to run that little bit better again. Capitals also makes reading a whole lot easier. My Defender and travels |
And1145 Member Since: 04 Sep 2013 Location: Howden Posts: 30 ![]() ![]() ![]() |
I had exactly the same problem with the intercooler. One of the pins did not line up at all to drop into the radiator mounting hole. I chose to cut the pin off the intercooler, drill a hole in the mount and bolt it.
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
^^^ Similar problem as mine when I fitted a larger intercooler, the two strengthening bars that go at 45 degrees needed a trim to allow for the extra width, it didn't take long though.
I'd like to know more about the exhaust if you have time, what do you think of it? Is it a nice tone compared to the std one? Roughly what was the cost and can I get one for a Td5? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
The alive td5 exhaust is the fantastic. I miss it sooo much. I had the one with the cherry bomb Center box so no resonance inside. Wish you could get the same sound from a Tdci.
Andy. |
Yes more of a deeper growl/raspy sound now, Also notice the difference regards a little more power, cant really hear it whilst driving unless you go through a tunnel or built up area, But i did stand by the side of the road as my mate drove by several times and yes, It does sound nice, not over the top.But not as nice as a TD5 with the same.
And i reckon the whole system weighs less than the center box alone !!! LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
Abbreviation sorted
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Thanks for the kind words about our exhaust system.
![]() Just a shame you never took an alive remap, with more low end torque as standard, and our ultimate Intercooler, which fits and performs flawlessly. Following the flock is not always the best choice! ![]() ![]() ![]() ![]() ![]() ![]() Kind Regards, Gary. |
ahhh but Gary, some times the sheep follow for a reason.
![]() That exhaust looks stainless, looks like some nose work also. Do you do it in standard exhaust type material however. My Defender and travels |
Of course everyone follows for a reason. My point is regarding how well informed/misinformed people are about other options that are available for tuning.
![]() Our sports exhausts are all made from 304 grade stainless steel, the material of choice for high quality aftermarket exhausts. The original Land Rover exhaust is made from 409 grade stainless steel, using mild steel flanges, so more prone to corrosion. |
The flanges certainly do rust.
Is there a full system including CAT? Any would samples of the exhaust note Gary? ![]() |
