![]() | Home > Technical > Help please |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 ![]() ![]() ![]() |
Main reason for asking is there is a white wire and a black wire...is it very safe to assume the black is the earth? Thats all i need to know.....i was to open them up and have a look......but it does beg the question....how do you change a bulb when needed!
Does anyone know the answer to the above....please!
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
If it's just a bog std bulb then it won't matter
Does if i cant get into the unit! Any idea on the white and black wire comeing put the back......they look fab but they aint wired ul yet cos i dont want to get it wrong and blow the bulb before they get to work! ....someone must know........
Surely if it's a standard bulb, it won't matter which is earth and which is live.
Oh really? I do t understand electrics!! I thought i may end up having a permanent live to the casing? No?
I'm no electrics expert but if it was earthed through the casing wouldn't only one wire be coming out? You might be best waiting for more electrical minds to add there thoughts.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
The white will be the live the black will be the earth. You could do a continuity test of the two wires to the body to confirm if unsure. Can't help with getting into the light, but posting a photo would be a good idea.
Andy |
Like I said, if it's just a bulb then it won't matter which way around. Try it on a battery.
yes I agree , only problem is if the bulb earth is not insulated from the body of the lamp really only way is to check with a multimeter , check for continuity between wires and body of lamp but they must come apart somehow for bulb change , if they are that hard to get apart or you have to damage them to get apart I wouldn't be fitting them |
