Home > In Car Electronics > Sound quality, file type. |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
MP3 is notorious for poor sound quality, especially if downloaded from less than legit sources... Alternatives exist, but not at the same file size (much larger). I believe it is the 'Bitrate' of an MP3 that affects the sound quality. Are you playing through iPod or another MP3 player? I believe Apple have a lossless file system you can use.
5th Aug 2014 10:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20552 |
If using iTunes / iPod you can set the bit rate to match across all songs.
You can also convert mp3 to AAC format for free too. |
5th Aug 2014 10:39pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
It's a Pure digital radio, with front USB connection. It specifically recognises the iPod, and plays music off it. It also recognises the iPad as an iPod.
I will try equalising the bit rate then, and move onto changing file type after. Cheers guys 1998 110 300Tdi White Hard Top |
6th Aug 2014 11:27am |
You should see the option in the lower pane of the widow when the device is connected to iTunes and selected.
6th Aug 2014 11:53am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Do your Mp3 files have this distortion when you listen to them on your iPad if not then it is a connectivity problem with your head unit. Try using a new connection lead.
MP3 files at 320 are almost CD quality and are free of distortion providing the source is free of distortion. At worse an MP3 file will have artefacts that can be heard in other ways, such as chirps in very high frequencies, or a little instability in sound levels over time, or poor stereo imaging. Try also using another computer to download or burn your CD’s it is possible that a fault on your PC or laptop is causing the problem, if you are using your phone to download your MP3’s this could also be causing it as it is a known issue with some phones. I use a TomTom to transmit my MP3’s to my head unit via the TomTom’s built in radio transmitter, I transmit on 107 which is a frequency that is not used by Radio broadcasters, the quality of the sound is excellent. |
6th Aug 2014 12:04pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
I play mp3 files through a usb stick via a £69 halfords pioneer. Works perfectly. 1953 80"
1987 mini city e 2011 90" |
8th Aug 2014 8:46am |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Are you suggesting this will fix any inherent issue with the original MP3? |
8th Aug 2014 11:02am |
It can't do.
You can convert things down in quality but never up, that would require finding data that's been chucked away in the compression process. |
11th Aug 2014 1:13pm |
