![]() | Home > In Car Electronics > rca cable |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1438 ![]() ![]() ![]() |
You should find room somewhere! Try poking a separate thickish piece of wire through first. eg welding rod, coat hanger . A small bit of foam gaffer tapped to the end will stop you damaging stuff
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20737 ![]() ![]() |
Send them on their own indoor can't route.
Mine go down the drivers sued just up and left of the clutch, you'll see a gap straight through there if you look up from the footwell. Then go under the matting / carpeting. Mine then goes between the handbrake and gearbox tunnel and then on up under my matting. (Or carpet) ![]() |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
Cheers for the tips i will have alook at lunch and report back 2004 TD5 Defender 90 xs station wagon
Did you manage to have a gander John?
Yes steve i did have a look, de to me having too many accessorys behind their it doesnt look promising bit i might get the file/holesaw set out
![]() the focal sub seams to come with iso wiring and no rca cables so i am going to look more closely at this as it could be the easy answer if it will mount to the back of the cubby 2004 TD5 Defender 90 xs station wagon |
