Home > Td5 > Most powerful td5 defender
Neil5489
I know that these engines are fairly easy to tune and increase the power. But as with most there will be a ceiling and to go beyond involves more in depth work and a lot more cash. But just out of curiosity what actual power figures are people getting for the mods they have done and what's the most powerful real world td5 out there. I read something about a stroked td5 in Australia? That was producing 258bhp and 430 ft/lbs of torquiness. [/url]
Post #349685 5th Aug 2014 4:32pm
ibexman
I've seen one bored to 2.8. Don't know BHP figures ask Ian aka Porny or Pete Bas. Thumbs Up
Post #349691 5th Aug 2014 5:09pm
Neil5489
It would be interesting to know who's getting what power and what they've had to do to get it.
Post #349702 5th Aug 2014 5:52pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Mine is just over 170bhp tested on a rolling road running alive remap, and intercooler. Fancying a vgt turbo but just had new gearbox so not the pennies.
Think there was a td5 pushing over 200bhp on the roiling road day running basically the same but with a turbo and different map but don't hold me to that as was 12 months ago.
Post #349714 5th Aug 2014 6:50pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
The famous 2.8 was stroked using a custom crank. Great for more grunt in the low revs but for more power your going to want it to spin faster as well. www.td5.org
Post #349838 6th Aug 2014 6:12am
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Sphere 170 bhp is very good for remap and intercooler and i bet it goes well. Im guessing the other side of that your going to need to start spening serious money 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #349849 6th Aug 2014 6:49am
roel
I use a PSI power box. Yes it is probably not as good as a proper tune and surely not as good as tune for a respectable tuner but I got it cheap and it is giving me probably around a 150 HP (not measured) (PSi quotes 160 HP and 374 NM) But I think my 90 is not perfect so I assume I get less.
I got it cheap and what I like I can switch it on and off. I normally don't use it on the road only if needed. Whistle
But use it often off-road but as it is easily switchable also only when I think I will need it.
It makes a lot off difference I can say that.
My almost worn clutch doesn't slip when the box is switched off but it will slip in any gear when I give full throttle above 2000 rpm. Roel
2003 90 Td5 (2009-now)
Post #349861 6th Aug 2014 7:17am
Nick999
I have a 2015 2.2 puma 90 with an Alive tuning high flow intercooler, remap and EGR delete. It’s around 175bhp, 450nm / 330ftlbs torque. It pulls a penman military trailer up a steep hill at 70mph and will sit all day long a 90 on the motorway without putting my foot all the way down. It shifts and sounds good with an Alive tuning sports exhaust. Not as nice sounding as a TD5 but nice.
Post #869826 26th Nov 2020 11:19pm
Likeomg
I've heard rumours of 240+
seen a dyno chart or 2 of 230
Big power puts a lot of strain on them, I had a spicy 2.4 - big turbo etc, had a few issues and decided to turn it down a little, its still fairly spicy..
Post #869835 27th Nov 2020 1:34am
bankz5152
My 110 is 230bhp and 525nm torque. It had to be pushed further but we where limited by the size of the factory airbox, currently looking at options for larger airboxes! Once ive got that sorted should be able to push a bit more
Currrently done over 6,000miles at that level on and off road without issue (well I blew up a DMF Laughing ) its also driven everyday by me.
Empire tuned
Empire VNT
CJM manifold
4 bar MAP sensor
3" Downpipe
Allisport IC
3.5" air intake
Egr blanked
On a calibrated Maha Dyno. The graph is a little out as after we pushed through 500nm it rescaled to 1000nm. The mapping has since been adjusted.
 Instagram @defender_ventures
Empire Tuning - Agent
Post #869838 27th Nov 2020 5:57am
lightning
Good grief that's some going for a TD5, shows how much reserve they have.
Post #869942 27th Nov 2020 3:35pm
LR90XS2011
Take a look at Alive on Instagram they are quoting some big figures DEFENDER 90 TDCI XS,
Post #869956 27th Nov 2020 5:10pm
bankz5152
Quoting yes, yet to actually prove it! Interesting tho to see what they get from that Darkside turbo. Instagram @defender_ventures
Post #869973 27th Nov 2020 5:59pm
jst
we ran a td5 Trophy vehicle that was just over 200hp, we always took a spare head and engine with us and usually ended up fitting them, so yes they make the power but not always for very long in my experience. this was some time ago now and things move on, maybe the reliability is there now on 200bhp+, it wasnt when we were playing around. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #869988 27th Nov 2020 6:43pm
Procta
What is the MPG like on wound up TD5s? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #870045 28th Nov 2020 2:01am
