![]() | Home > Td5 > quick question. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6150 ![]() ![]() ![]() |
COuld be all sorts of things....
UJ on its way out in one of the proshafts. loose prop bolts, gearbox mounting rubber failing, possibly a bearing inside the gearbox on its way out. Or it might just be the gearstick itself loose! i think there's a nylon bush thing that the bottom of the gearstick sits in. this could be loose/broken. |
aj_slr Member Since: 23 Jun 2010 Location: Tasmania Posts: 3 ![]() ![]() ![]() |
To me it feels like the gear shift lever. The gear box is quiet at all speeds and engine revs. The noise starts at 80 KPM in 4th and just little in third. There is no vibration from the box. If I hold the gear lever tight the noise seems to stop. The gear oil was changed 400km ago and there was no metal on the magnet plug. The oil was also very clean.
I was tinking it may be the location return spring on the gear lever at top of the box. Do others have the noise. |
