Home > Maintenance & Modifications > Axle Breather Tubes
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Axle Breather Tubes
Hi Folks,
Where do they terminate??
One end is connected to the axle, but where does the other end normally get secured (factory position)?
Am looking at extending or replacing and routing into the engine bay so it can run up the snorkel side.
In the engine bay, I can see two hoses, which as I understand is the g/box and transfer box.
Andy
Post #349094 2nd Aug 2014 9:45pm
excossack
Not sure if mine are factory or not, but the tubes terminate by the air box. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #349096 2nd Aug 2014 10:00pm
Near the EGR, two looped ends (think walking stick shape) between the EGR and OS wing. Near a black bracket.
Post #349100 2nd Aug 2014 10:13pm
ROBBONTHEROCK
Hi, do they terminate into the air box?
I know that the two "hooked" ones in the engine bay are the T/box and g/box.......but maybe I'm wrong?
Andy
Post #349101 2nd Aug 2014 10:14pm
I always thought they were axle breathers, you can trace them from underneath.
Post #349103 2nd Aug 2014 10:21pm
ROBBONTHEROCK
Ok, fair play I may be wrong Wink
So where are the g/box and transfer box ones located?
Andy
Post #349104 2nd Aug 2014 10:22pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
On my TD5 the G/box and T/Box breathers appear behind the head- a pair together.
The axles, Front one appears slightly inboard and below the airbox, the rear was tucked up under the rear seat box somewhere.
Chris
Post #356472 8th Sep 2014 11:44am
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
The rear axle one is usually located in the back of the N/S/R wheel arch, and I think it has a one-way valve on it. Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #356657 8th Sep 2014 11:31pm
Chris86
Is that not the breather from the tank?
Chris
Post #356739 9th Sep 2014 12:07pm
