Home > Puma (Tdci) > Towing with Defender 2.2 TDCI |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1577 |
Mine seems to do 26mpg.
I have been towing three tonne today and pull it fine. Hill starts are slow and brakes aren't the best. Keep your speed at 60 or less and it's a very good tower. 110 tows better than a 90. The extra weight and length of the 110 means it will tow upto the 3.5 tonne limit with no problems. |
2nd Aug 2014 1:38pm |
not so sure about the 110 being better at towing than a 90
1, 110 is heavier already 2 , tow ball is further away from back axle , closer is better |
2nd Aug 2014 1:56pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5101 |
I think it depends what your towing. I have always found that if towing a caravan then a 110 seems to give a more comfortable ride, however trailers seem better with a 90. Well to me anyhow!
2nd Aug 2014 2:21pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
I've owned and towed with a fair few of both and found that the less choppy ride of a 110 equals less pitch and bounce at the hitch - but there's not much in it. Real world towing I found there is less engine braking with the 2.2 so you have to use the brakes and gearbox a bit more. For me unless it is outrageous and there is obviously a problem fuel consumption never really enters into the equation, I just don't run a Defender on the basis of economy. Steve.
2nd Aug 2014 2:30pm |
If your towing a light load say under 2 tonne the 90 is just as good. But when you get closer to the 3.5 tonne the extra weight and harder rear springs really make for more stable towing.
2nd Aug 2014 3:58pm |
