Home > Maintenance & Modifications > seatbase recaro seats defender |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Looks like you have aftermarket ones not the genuine LR recaros
29th Jul 2014 10:18am |
maar10 Member Since: 02 Feb 2014 Location: ZH Posts: 52 |
correct they are the normal recaro sportster cs ones (i edited the post now). But i can't seem to find pictures of the base they seem misplaced now almost touching doors and higher then old seats. I like the seats but hope they gave wrong base.
29th Jul 2014 10:22am |
Looks like you have 2 sub frames LR seats sit really low
29th Jul 2014 10:46am |
I found adapters online and this one:
I hope someone overhere has better pictures so i can tell our Recaro dealer there are better mounts for Land Rover. Last edited by maar10 on 29th Jul 2014 11:01am. Edited 1 time in total |
29th Jul 2014 10:51am |
Take out bottom subframe and mount to seatbox
Looks like wrong subframe ,maybe someone will be along later who has recaros (Where's Matt) To point you in the right direction cheers Chris
29th Jul 2014 10:55am |
Thanks Chris!
29th Jul 2014 10:57am |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Looks like I see two more holes above on the frame? If it's the same at the back, maybe it's possible to cut a bit off so you can mount it at the holes above? This way your seat will get to sit lower for more space.
29th Jul 2014 11:32am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Can't help I'm afraid, I've only ever fitted Genuine SVX Recaros as your picture above, sorry
29th Jul 2014 11:33am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2035 |
Recaros should mount on the original Land Rover seat runners with the right subframe adapters. Here are mine mounted on Mud rails.
Speak to Alive Tuning, Twisted Performance, or TMD Land Rover to get the right subframes. Click image to enlarge Click image to enlarge |
29th Jul 2014 11:53am |
We can however supply a 'plug and play' wiring harness for the seat heaters complete with Genuine switches
http://www.farrowsclassics.co.uk/fcx-Heated-seat-loom-kit.html |
29th Jul 2014 12:09pm |
Thanks. I will ask them to cut the two holes (out of three). After that i still want to travel to UK to shop for more stuff so i will also visit FCX. Thanks for providing me more pictures DAZ110!
29th Jul 2014 12:21pm |
29th Jul 2014 12:32pm |
flexed it thanks!
29th Jul 2014 7:25pm |
