Home > Tdi > Fitted a new Winch Bumper but need to know
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
I have just bought and fitted a new winch bumper and used the existing bumper bolts are these ok to use or do i need H/D bumper bolts ?
 Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #347894 27th Jul 2014 6:18pm
Waldo
What is the rating stamped on the end of the bolt heads??
If we know that we can work out how much force would take to shear those bolts.. If the winch you are going to mount can't pull as much as will take to break to bolt then you're fine.
Oh also what size is the bolt
Will Defender 90 XS TD5 (03 Reg)
Post #347937 27th Jul 2014 9:17pm
cornish rattler
Cheers i didn't think of that but i will remove one of the bolts later measure it and see if i can read anything on the bolt head and get back to you later Thumbs Up Graham
Post #347988 28th Jul 2014 9:04am
munch90
bumper bolts are m10 , BUT you need to know the grade of metal which should be stamped on the head
if you cant find the markings , may be easier to get new ones that are marked , so you know there right just in case someone has put weaker bolts in
you could get some cap socket ( allen ) bolts then resin the holes in the heads to help with security to stop someone unbolting your bumper
something like this eBay item number:
eBay Item No. 360611556348
Post #347991 28th Jul 2014 9:21am
Standard front bumper bolts are the usual off-the-shelf HT grade 8.8. A winch bumper is usually also braced to the lashing ring mounting point on the chassis (IIRC again M10/8.Cool, so a minimum of 6 mounting mounts. This is entirely adequate for normal winches (if you're fitting a 12,000lbf winch you might want to add reinforcement, but 8,000lbf or 10,000lbf should be fine).
You can opt for socket head caps in place of hex head bolts, by default these are grade 10.9.
Bear in mind though that it is probably better to rip the bumper of the chassis than to rip the mounting mounts out of the chassis, so there's no real point making the bolts the strongest part of the system.
Make sure you know what you're doing with your winch and you'll be fine. Remember that if you double the line back to the front bumper you're potentially doubling the load on the bumper (I have seen people run a triple line using two snatch blocks back to the bumper of the winching vehicle before now - enough to make me (in the words of Mythbusters) "de-ass the area wit' the quickness").
Post #348003 28th Jul 2014 10:46am
cornish rattler
Yeah i removed all 4 bolts in the end but couldn't work out what was stamped on them so as what has been said i will buy some new ones as you say they could be the wrong ones already fitted anyway Smile Graham
Post #348098 28th Jul 2014 8:20pm
