![]() | Home > In Car Electronics > wiring multiple Carling switches |
I think there's nothing wrong with that, as long as you use the correct wire diameter. Note that, if you have for instance 6 switches and they are all on, then the first loop gets 6 times the current needed for the relays. I guess a relay needs approx. 200-300 mA, so with a decent wire size that won't be a problem.
I wired my muddstuff panel with 7 carling switches this same way. ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5895 ![]() ![]() ![]() |
So some 16amp thin wall would suffice. The idea dawned on me while cooking tea... Normally I run a positive wiring up the to switch and then another wire back down. So plenty of wire knocking around. 1999 Defender TD5 110
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
I suppose it would depend on how many switches you have and what the switches were for. What would the effect of that one fuse blowing be, loss of all headlights or just a load of relatively unimportant auxiliaries? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
The switches are for things like, rear work lights, front spot lights, orange strobe lights. 1999 Defender TD5 110
My roof console has comon neg +feed & lights however the output always goes to a relay
Each switch will have a relay, with a fuse for each circuit. 1999 Defender TD5 110
