Home > Td5 > Td5 tune advice |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Upgrade intercooler: £300
Conservative Remap (~165hp): £300 Shouldn't have any negative long term side effects as long as you don't floor it everywhere, might reduce the lifespan of the clutch slightly but it's worth it. Contact Gary at Alive tunning |
21st Jul 2014 4:43pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
I have intercooler and stage 2 tune from pete at bell autos the best thing I ever did along with disco transfer box for better cruising speed 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
21st Jul 2014 6:06pm |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
Another for the best mod. Stage 2 irb ish (nicked some parts from a previous motor) and disco box. So good don't worry about cost just go for it.
21st Jul 2014 6:31pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8102 |
i had an early td5 (99 plate) and went for a new ECU from JE Eng in 2000 at 20k miles. i did another 90k on it with their stage 1 remap, no other map/intercooler mods but egr removed, loved it. good economy and great for towing. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Jul 2014 8:26pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Another vote for Gary at Alive, I had a tune done on my late Td5, nothing major just a fairly mild stg 1 tune for added mid range torque to help drivability and I also now get better fuel economy too, I did add a bigger intercooler, removed the egr etc at the same time, it's much nicer now. I wouldn't go mad and try getting 200bhp, it's just not needed. Give Gary a call or I'm sure he'll do you a deal at Billing, he's very knowledgable (but knows it!!) |
21st Jul 2014 9:17pm |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
CSK (Chris) did mine, What an improvement! I have just a remap (stage 2), no intercooler or exhaust changes yet.
I tow horse trailers everywhere (400 mile trips are not uncommon), and the usable torque is fantastic. Also, nobbing off boy racers at the traffic lights in Farmer Giles truck never gets old. |
22nd Jul 2014 8:16am |
Butters Member Since: 14 Mar 2013 Location: North Wales Posts: 23 |
I would say....
If you have a better inter cooler like allisport, loose the cat, loose the egr, remap the engine and use the BAS bell auto services boost box you will be very happy with the results. The boost box I was very sceptical about but it actually works. Avoid over boosting beyond the 18psi that BAS say to turn it up to as there's a fuse inside the circuitry which blows then it's a new boost box (talking from experience got a bit greedy and didn't listen to BAS advice, bad move... A 2.9 turns steering box from adwest engineering is also a good move less banging your elbows on the window frame, but beware the tighter and higher geared steering boxes only last 2-3 yrs then a new one again from experience. Overdrive from roverdrive would be my final mod suggestion, doesn't mess with your ratios for work, towing or GOLF beating at the lights like fitting a disco transfer box which is obviously tons cheaper. 30mm spacers and turn the steering stops right back in so you can turn on a sixpence. Lumbar support into seats, pump up airbag from exmoor trim retailers and it's an easy job. Defender TD5 110 DC (Silver) Range Rover Vogue TD6 L322 2006> (Black) |
28th Aug 2014 11:45pm |
