Home > In Car Electronics > Double Din Facia Fitting
saltydog
2015 Defender 110 Puma 2.2 USW Corris Grey
I am considering fitting a double din facia into my Defender.
I am wondering if there are any companies anyone can recommend to do an a1 job for me in supplying and fitting one.
Cheers,
Salty LR Defender 110 XS Utility Wagon
LR Discovery 2.0 Sport HSE
LR Discovery 4 Landmark
Post #346417 20th Jul 2014 8:57am
You could do it yourself no problems. Thumbs Up
We / I can guide you if need be, and the best part all free of charge. Razz
Post #346429 20th Jul 2014 9:17am
Cheshire110
Also as the switch relocation panel requires cutting the dash and extending one or two switches wiring, I'm not sure any of the usual places would be happy to do that. Halfords certainly wouldn't touch it!
That would make it a job for a Land Rover customiser, most of whom are on here. Not sure what they each charge but certainly chris @ CSK, FCX, Brendan etc all offer it I think.
See my thread here of fitting my parrot asteroid smart double din, complete with video on the last page: http://www.defender2.net/forum/topic26531.html Cheers, David
Post #346438 20th Jul 2014 9:46am
Thank you for the recommendation Thumbs Up
We no longer offer a fitting service as actually this is a time consuming job and isn't as easy as it may look.
The panels do not include the heater / clock section at the top, this has to be cut off of your existing centre panel and reused (we have take off panels in stock at Ł50 each ready for you to adapt if you want to keep your existing as a spare)
There is an existing bracket behind the dash that is welded to the bar that holds the dash to the bulkhead, this should be removed to stop the new stereo being pushed upwards (some companies just bend this)
There is also a bracket that holds the heater pipes that needs to be modified for clearance.
Cutting the hole for the switch panel can weaken the fixing points for the dash panel so careful positioning is required.
Dependant on which switches you relocate, it is not necessary to extend cables.
We have a leather trimmed cubby that has positions for the hazard switch and three other switches which eliminates having to cut the dash at all and allows reinstatement of the original single DIN stereo come selling time.
There are very able installers out there but I haven't come across one yet.
Post #346454 20th Jul 2014 10:18am
Post #346543 20th Jul 2014 5:12pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
i had mine fitted, its an Alpine Navi/Radio, love it
it's so much better fix fitting, you don't have the hassle with all those cabels plugged in all over the place.
 LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4
Defender TD4 110 Hardtop 2.2
Post #347323 24th Jul 2014 6:52am
