Home > Maintenance & Modifications > Checker Plate Dilemma... |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
My 90XS is a worker, landfill sites, road works, quarries etc and without chequer plate on sills and wingtops would suffer from rigger boot scuffing, spanner scrapes,dents and all. Would rather not use it but without it the 90 would be scruffy. Black Mammouth 3mm plate on Santorini Black. It's like putting Waxoyl on the outside, a necessity for some of us. Use Rivnuts and gasket on wingtops.
Steve |
29th Mar 2014 11:37am |
I always use gasket it stops the crud from accumilating behind it. When I fitted the Entreq door strips I had to remove the sill chequerplate that didn't have any gasket. I was amazed at the 'dirt gasket' behind it and used a wallpaper scraper to remove the initial build up. I used butyl pondliner I had left over to make some gaskets before refitting. The bonnet I used the gaskets supplied and sealed up using black Sikaflex on the rest. If you go through life with your head in the sand....all people will see is an ar5e!!
Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 20th May 2014 11:40am. Edited 1 time in total |
29th Mar 2014 12:54pm |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 |
So does the black wear off, if it's anodised then I guess it will scratch and eventually wear away? If it's silver that matters less? |
29th Mar 2014 4:18pm |
Black and black... Any pics? |
29th Mar 2014 4:19pm |
When I did No 1 I used silicon rubber and wiped the edge with petrol... Worked a treat until the silicon began to degrade. I'm sure with care a decent seal to stop the mud et al that just rubs evening away as inevitably the metals will move against each other... |
29th Mar 2014 4:21pm |
Neil5489 Member Since: 19 Dec 2013 Location: Cheshire Posts: 87 |
Don't do it!!! Chequer plate is the devil!!!
30th Mar 2014 12:24pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Why not go www.Turtleshell.co ? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
30th Mar 2014 8:52pm |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1383 |
[URL=][/URL]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Euro-Leafing to infinity and beyond..... |
31st Mar 2014 11:38am |
YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 208 |
Your wish... Click image to enlarge 2013 Defender 110 XS DCPU |
31st Mar 2014 11:48am |
Brilliant thanks... where is that kit from?
31st Mar 2014 11:56am |
The kit came from MM 4x4 in Droitwich (the wing tops are done too). I didn't order it directly myself, but had it added on when it was in for the lid over the load area. 2013 Defender 110 XS DCPU
31st Mar 2014 12:45pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 523 |
@strang
31st Mar 2014 4:08pm |
Think of the scratches in the paint if you don't: Click image to enlarge |
18th Jul 2014 2:07pm |
Dale Member Since: 14 Jul 2014 Location: Bristol Posts: 79 |
Guess I'm in the like camp. I must be a chequer plate bitch!
18th Jul 2014 6:29pm |
