![]() | Home > Td5 > TD5 Fuel Filter Housing |
andylee Member Since: 29 Jun 2016 Location: South East Posts: 98 ![]() ![]() |
Hi there i've just been digging on the net for some information and came across this post.
i have exactly the same issue with my fuel filter housing as in it has crumbled away where it attaches to the chassis. I am pretty sure the replacement part i need is WJN000020 as that matches with my vin (2003 TD5) i would just like to ask you how difficult was it to replace ? Im assuming that as soon as i disconnect the fuel pipes from the nipples it will start to pour diesel out ? im just wondering weather this is a job best done by an experienced mechanic or if I can manage to do it ? Any advice much appreciated, thanks Andy |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
It's a pretty easy job - my housing broke away when I tried to replace the filter so I had to do this a few months back.
When you disconnect the four fuel pipes some fuel will leak out but not a lot. Have a look at the following post, it has some excellent advice to do with the NRV/Bleed Valves being installed into the wrong ports on the newly delivered filter head. http://www.defender2.net/forum/topic41101.html |
