Home > Puma (Tdci) > Changing ignition lock ..help
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi .. My ignition barrel (on my 2008 110) and lock has finally given up the ghost. It just won't turn .. And I need to get to work on Monday
Therefore. Help please!
I've got no chance of getting a new ignition lock before Monday so I was thinking of removing the lock from e column and removing the ignition switch from the rear of the lock assembly so I can start it.
What is involved? It looks like the whole dash has to come out to get access to the sheer bolts on the underside of the lock assembly Shocked .. Is it easy enough?
Any advice would be welcomed as I want to get it running early tomorrow morning.
Thanks. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #344738 12th Jul 2014 6:53pm
carrotbay
.. or .. is it possible to remove the steering column and change the lock on the bench without removing all the dash? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #344760 12th Jul 2014 8:31pm
munch90
cut through the back of the lock with a hacksaw blade with cloth wrapped round one end , being careful of column and wiring ?
Post #344761 12th Jul 2014 8:35pm
mk1collector
Shocked I'd try graphite powder first!!!
Post #344763 12th Jul 2014 8:44pm
carrotbay
Ok .. Will try and get some today before I start stripping everything out. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #344837 13th Jul 2014 10:10am
carrotbay
I've been to get some graphite powder and the lock is much better (ie it works) .. so thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #344905 13th Jul 2014 5:00pm
mk1collector
Thumbs Up
Post #344961 13th Jul 2014 7:26pm
