Home > Maintenance & Modifications > Manmouth - Pumatech chequer plate bonnet protection.
Cold_n_Wet
Norway
Big parcel arrived today, no instructions, guess I just throw it on and drill and screw.
Looking forward to mount it, so looking for anyone´s experience.
I have some different length screws in the bag and wondered where they go ?
Glen "Rafiki" 2007 110 STW - Rolling rebuild.
Post #344026 9th Jul 2014 3:03pm
K9F
All you need to know about fitting.....
Page 3....
http://www.defender2.net/forum/topic7709.h...p;start=30 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #344047 9th Jul 2014 5:01pm
Post #344048 9th Jul 2014 5:01pm
Cold_n_Wet
Norway
Thanks chaps,
I got no gasket foam in the kit and its not mentioned on the TF web page.
Stainless screws supplied Smile
Thumbs Up "Rafiki" 2007 110 STW - Rolling rebuild.
Post #344235 10th Jul 2014 12:36pm
K9F
I got FOUR gaskets with mine? Top tip....go to a decent acquatic centre, buy a couple of metres of butyl pondliner and make your own gaskets. Thumbs Up
Will dig out the photo of the gaskets and repost it for you. Thumbs Up
**EDIT**
Here they are.... Thumbs Up
Post #344237 10th Jul 2014 12:42pm
Cold_n_Wet
Norway
Bow down Bow down Thank you Thumbs Up "Rafiki" 2007 110 STW - Rolling rebuild.
Post #344238 10th Jul 2014 12:46pm
K9F
Very welcome. Thumbs Up
Not sure of the proportion of long and short bolts you've been supplied with but I could have done with more long less short. They did say they were going to address this when I gave them feedback.
K9F wrote:
TOP TIP.....dependant on how the chequerplate lies some of the short bolts do not quite fit through the chequerplate and the bonnet. By using one of the long bolts it is possible to draw the chequerplate to the bonnet. Extract the long bolt ant the short one now fits! I used Sikaflex to wet assemble all the bolts to prevent ingress of moisture and air to prevent corrosion.
Post #344239 10th Jul 2014 12:47pm
smb
TBH, the gasket doesn't do much other than to aid positioning when marking up the holes and stop vibration/resonance when driving. Some would say it stops scratching the bonnet, but then why would you be bothered about that when you are drilling a dozen or so holes in the bonnet!!
Buy yourself a couple of tubes of really good engine gasket sealant(I have black on mine) and don't be afraid to overload the back of the plate. Try and spread a 2-3mm thickness all over. 3-5mm would be ideal as when you start to bolt it to the bonnet and tighten it up it will fill all the voids and push the excess out the edges. This way you create a 'sandwich' which when set will give the bonnet enough extra strength to walk and even jump on.
You have to remember that the chequer plate whilst looking similar does not fully match the contours/shape of the bonnet so will always have week spots unless you create this 'sandwich'.
Obviously, you do not need to go to this extent if you are not putting any weight on it Whistle
Post #344241 10th Jul 2014 12:54pm
K9F
CnW,
Is this underway yet? Drilling 28 holes in an unblemished bonnet is not for the faint-hearted? If you need any more pictures just holler!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #344550 11th Jul 2014 4:12pm
Cold_n_Wet
Norway
I have not had time, been getting the trailer ready for the norwegian national event.
So the pumatech is put on hold for at least 3 weeks, then I hope my helper is back.
I will be masking up like in the pictures, measuring 4 - 5 times get the pilot holes drilled, and then either use the suggested gasket material or RTV silicon or similar.
might just be starting with cleco´s.
The bonnet is steel if memory serves me correct, then I need to get som primer and touch up paint as well.
Post #345130 14th Jul 2014 2:26pm
AndrewS
I drilled more holes in the plate to get a better fit on mine Thumbs Up
Post #345151 14th Jul 2014 4:11pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
aka drilled the holes oversize accidentally and had to drill more Whistle My Disco 'best bits'
Defender 110 XS CSW 2013
Post #345156 14th Jul 2014 4:27pm
