Home > Puma (Tdci) > For anyone who cares |
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 |
mike how old is your landy milage ect , cheers paul BETTER TO REGRET THE THINGS YOU'VE DONE THAN REGRET THE THINGS YOU HAVE'NT
14th Jun 2010 3:27pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Thanks MSE
Another thing to the list of possible failures... Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
14th Jun 2010 3:50pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
2yrs 14k Mike
By all accounts the properly fitted 3rd should do it
Still wouldnt change it Mike |
14th Jun 2010 3:52pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
A suggestion: Put your left foot on the clutch pedal only if you want to change gears. I think your dealer is right in telling that you keep your foot on the clutch pedal.
Sorry I couldn't resist. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
14th Jun 2010 5:55pm |
I do! Care that is! You need to get out more! Glad to hear you still wouldn't change it, fingers crossed for you! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Jun 2010 6:57pm |
Im hurt - never in all my years do i drive with my foot on the clutch, other than to change gear I think they either put an original spec in when they changed it - or didnt change it properly. Although - apparently 3rd clutches are unusual which is why they modified it. unfortunately i do...just not in the defender. I dont use it for work - the other Land Rovers do that so this one just does the holiday trips - still in 27months ish of ownership its been at the dealers for nearly 7 months with 3 central problems: Clutch Roof Leak The inability of stratstone meant it would go in for 3 weeks - say for the leak, come out not fixed with damage - say scratches, broken parts etc. When they replaced the clutch they broke the selector - it took them a week to do the clutch (after 4 visits) one where they told me they had done it - ignoring the noise, they hadnt removed it the waxoyl was over the bolts! then 1 week to repair the selector (needing parts) on that trip they tore the carpet, didnt refit all the bolts (loose floor ) damaged the cubby box and didnt refit the low range selector Guy Salmon are as good as gold and with about 5ish months left of its warranty the original faults are starting to be fixed. Maybe soon ill be able to use it. Let it be a lesson to you - LR make some good cars - the dealers are masters at not keeping them that way Mike |
14th Jun 2010 7:27pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Clutch number three just been fitted to my 110, this is replacing the revised version fitted a few months back !
Not bad, 7,000 miles and on clutch number three Not got the vehicle back yet, 4 days so far for it's first service - might be out Friday ! Bob |
24th Jun 2010 3:50pm |
