![]() | Home > Technical > Galv bulkhead |
Welcome to the site Lyon99,
I did a little research on your behalf and a phonecall to this guy wouldn't cost much and would probably give you a solution: http://www.glencoyne.co.uk/bulkhead.htm If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Could also try here...
http://www.ashtreelandrover.com/pricelist.pdf Ive just oredered one from them for my 300tdi |
lyon99 Member Since: 05 Jun 2010 Location: Perthshire Posts: 20 ![]() ![]() ![]() |
Thanks to you both for the contact details for the galv bulkhead will try the monday, And see about ordering 1 , Thanks,
lyon99 110 Utility puma 2.4 2010 110 pick up 300 tdi 1998 Fendt 716 Vario |
