Home > Puma (Tdci) > PUMA 90 WON'T START
icon pacific
PUMA 90 WON'T START
New to the Forum.Thanks Martin.
My def 90 2.4 won't start after replacing AC pressure switch due to AC problem.Plugging in Lynx diagnostic under EMS, it says "control module not available".under Security/10AS/TRANSMITTERS-tried to follow procedures still won't start.Any possible leads/remedy highly appreciated.
Post #342946 5th Jul 2014 6:26am
Sounds simplistic but disconnect the battery for 30mins.
Then re-connect and check terminals are tight and then see what happens.
The Puma can be funny with it's electronics.
Worth a try.
Post #342993 5th Jul 2014 10:42am
icon pacific
Thank you custome90steve.will try and give feedback soonest.
Post #343006 5th Jul 2014 1:40pm
K9F
Did you replace the AC switch and have you disturbed something or did you disconnect the battery when you did it?
Check all your fuses and connections would perhaps be a good starting block? You can do that whilst you follow Steve's suggestion with the battery disconnected. Especially fuses 13, 30, 38, 39 and 41.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343009 5th Jul 2014 2:11pm
icon pacific
Thank you.While in a process of eliminating problems re AC I unplugged/plugged different relays to checked on connectivity or corrosion.The last thing we did was change the AC pressure switch.The engine was cranking but won't continue to run seems the fuel line was cut off.Anyway, will try the advice of Steve and check the fuses and connections.
Post #343020 5th Jul 2014 3:15pm
Good luck. Thumbs Up
Post #343027 5th Jul 2014 3:34pm
icon pacific
still NO! one thing i noticed when I turn the ignition key on , check engine,glow plug,oil and seatbelt lamps from cluster didn't show up.
Post #343188 6th Jul 2014 1:42pm
Andrea
Hey mate.
You've definitely popped a fuse. I would suggest taking them out individually and checking. I notice because your temp is in the red, typical of a blown fuse.
These pumas don't suffer very much from electrical issues, shouldn't have any at all really, even if abused. I have drowned my puma (not intentionally ) was crossing a river once and the road collapsed , became a crossing where water was just above the line of the windows, water had made its way into the section under the drivers seat where the fuse box is found, simply dried it out with a compressor have never had issues...... They quite robust. Touch wood
Good luck
Post #345663 16th Jul 2014 8:23pm
landy andy
Check fuses in under dash box and underseat.
Andy
Post #345673 16th Jul 2014 8:34pm
bell-auto-services
Temp guge at the max limit indicates either the engine ecu is not powered or damaged or the CAN wires to the instruments are not connected or damaged.
You didnt probe anthing into the AC switch wires did you ?
Pete
Post #345676 16th Jul 2014 8:39pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Also check the relays under the drivers seat. One of these supplies power to the ECU and if it becomes loose causes symptoms similar to this (temp in red, glow plug etc. not illuminating).
Post #345730 17th Jul 2014 6:50am
astoltz
South Africa
I also notice that the oil pressure light also is not eliminated 1997 Land Rover Defender 110 HT 2.8i
(BMW M52)
2009 Land Rover Defender 110 HT 2.4 TDCi(Puma)
Post #347311 24th Jul 2014 5:36am
