![]() | Home > Technical > puma timing belt chain |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Hi Tim, it's a chain:
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
Thankyou that some thing i dont have to worry about cheers
why don't you ? it could jump off the sprokets at speed and take the front of the engine off,couldn't it?, or on the other hand it could just break a link, look on the bright side ehTim ![]() only kiddin ![]() 1968 1/32 scale Britains 109 Pick up. |
Not only is the glass half empty, but also broken aye Grockle!! ![]() |
thanks you have a great sense humour with all the trouble with the rear diff i would nearly expect that to happen. but i still would not change .it a sort of cult thing having a defender cheers tim
rs2315 Member Since: 16 Sep 2012 Location: yorkshire Posts: 125 ![]() |
So a timing chain it is.
What is the service schedule with these chains? Mileage/age? Nothing lasts forever. rs2315. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
your right....nothing lasts forever but the chain will probably out last everything else.....so just worry about everything else instead
