Home > Technical > TDCi - fuel feed system
jst
is is an HP system all the way from the tank the same as a td5?
ie if i want a fuel feed supply do i need to go back to the tank or can i T it off a fuel line? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3428 29th Aug 2008 8:45am
foz.in.oz
Australia 2004 Defender 110 Td5 SW Bonatti Grey
No. The TD5 has the pump in the tank giving positive pressure in the fuel lines through the filter to the engine. The TDCi has a pump unit on the engine which creates a negative pressure in the fuel line drawing the fuel through the filter to the engine. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #3732 10th Sep 2008 6:14am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Question
Interesting.
Hence the issue of water being ingested via the fuel tank breather valve. A postive pressurised tank would not have the same problem.
Question Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #3733 10th Sep 2008 7:54am
jst
so if i needed to get a fuel supply for a webasto i would need to go straight to the tank then i guess? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3737 10th Sep 2008 8:37am
foz.in.oz
one_iota wrote:
Question
Interesting.
Question
The td5 tank doesn't get positive pressure, it still holds a partial vacuum as it drains, it just doesnt seem to get as big as the TDCi. When I open the fuel cap on my TD5 you can hear the air get sucked in when the seal breaks. I do have long range tanks though (150l). Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #3755 11th Sep 2008 6:34am
foz.in.oz
I guess you take it from the fuel return line, that would be under some pressure. Wether it would have the volume and pressure required for what you want I don't know. Taking a separate feed from the tank may indeed be a better/safer option. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #3756 11th Sep 2008 6:39am
jst
Webastos come with their own feed pump so i guess from the tank may be the way to go.
Thank you Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3760 11th Sep 2008 7:11am
TJ101
James
Would not bother with the webasto , Puma's have a heating system Thumbs Up
Just can not see the hassle of fitting / swapping over, worth it California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3764 11th Sep 2008 8:21am
jst
thats what i was thinking, ones at work seem to warm up a lot quicker than the td5 so i am unlikely to bother but was just wondering
maybe the tdci warms up quicker due to the lack of oil in the top part of the engine.......... Shocked Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3765 11th Sep 2008 8:27am
mse
The puma's warm up just a quickly as most modern cars (and like any other tdci ford) so i would say you wont need one.
Whilst im waiting i put the heated seats on (although we have only had 1 cold morning since April to test it) Mike
Post #3779 11th Sep 2008 4:30pm
