Home > Technical > Towing electrics |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
If you order the tow pack, comes with the 7 pin wire kit
If you order without the tow pack,, LR do the kit, but IIRC was under £20, then when up to over £60,, but is only a simple plug in the rear system,, so the wiring is at the rear already !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
28th Aug 2008 1:08pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 |
got a MPN for loom to plug into the existing one then? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th Aug 2008 7:41am |
Last one i had, for a TD5 was YWJ101500, (7 Pin N Type ) can not see them being a lot different to Puma
but order on description ! Did send it back, after the price when up 3 fold California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
29th Aug 2008 7:52am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 |
Not knowing any better I used a gen loom for the electrics. I used the small recess in the rear X member to house the socket. Then fed the electrics up over the chassis rails and into the big multiplug hanging there ready. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
29th Aug 2008 5:17pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
Green plug under the drivers rear arch - i know whis as when i collected it it was hanging down. Mike
29th Aug 2008 6:19pm |
excellent thanks guys
Mark - so you just purchased the loom and fitted yourself then? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th Aug 2008 7:20pm |
