Home > Off Topic > Hollow wall fixings
excossack
Hollow wall fixings
I have a shelf attached that needs to be attached to a plaster boarded wall. I have tried plugs but they pull out. So, I am thinking of trying;
http://www.toolstation.com/shop/Screws+Fix...930/p36548
What does the 4 x 32 refer to? 4mm thick screw and 32mm long?
Or, these
http://www.toolstation.com/shop/Screws+Fix...930/p53684 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #342354 2nd Jul 2014 10:04pm
bear100
Hollow wall anchor Thumbs Up
They will be your best fixings for plasterboard, you can also buy a gun which will expand them in the wall for you Thumbs Up
4mm thick and 32mm long Thumbs Up
The spring loaded ones are as much use as an ashtray on a motorbike 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #342355 2nd Jul 2014 10:08pm
excossack
Excellent - thanks. I have seen the guns in Toolstation 1999 Defender TD5 110
Regards
John M0VAZ
Post #342359 2nd Jul 2014 10:13pm
bear100
Thumbs Up they are not need but make life allot easier Mr. Green
Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #342362 2nd Jul 2014 10:21pm
excossack
Cheers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #342363 2nd Jul 2014 10:24pm
