Home > Td5 > td5 egr removal benefits if any
Page 2 of 2 <12
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Well I finally got round to removing the egr and fitting an alive blanking kit. My verdict? I SHOULD HAVE DONE IT SOONER, PERIOD. Acceleration is more refined, smoother. I'm well pleased Thumbs Up picture of my egr.awful
Post #342206 2nd Jul 2014 10:50am
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Now imagine what state you intercooler, hoses and inlet manifold are in.
Post #342221 2nd Jul 2014 12:28pm
roel
Exhaust gases shouldn't go through the intercooler. Roel
2003 90 Td5 (2009-now)
Post #342327 2nd Jul 2014 7:19pm
True, but that oily gunk has come from the crankcase breather not the exhaust.
It is highly likely that the turbo, intercooler, and MAF and MAP sensors are generously coated in the same stuff.
Post #342366 2nd Jul 2014 9:28pm
dancerdave
United Kingdom 2000 Defender 90 Td5 Exclusive HT Santorini Black
Just done mine along with dumping the centre exhaust box and first impressions are more lively and smoother. Its still not overly noisy which I was worried about Wink
Post #342389 2nd Jul 2014 11:01pm
roel
It will be oily till the egr valve and like the picture after that. Whistle Roel
Post #342493 3rd Jul 2014 11:52am
Neil5489
One of the best mods you can do. Clean the boost pressure sensor at the same time
Post #343211 6th Jul 2014 4:42pm
K9F
You can always stick a filter in the crankcase breather line. Thumbs Up
Just do a search under 'Provent'.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343221 6th Jul 2014 5:05pm
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
According to a chap I know who works for Cummins Diesel in R and D told me EGR gasses are actually slightly corrosive.
That's enough evidence to get shot for me!
I took the EGR and cat off my TD5 when I had one and it made the engine run more smoothly with a couple of MPG in my favour!
Kevin
Post #348125 28th Jul 2014 8:35pm
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Removing the EGR is not enough, on td5 you will need a filter on the crankcase like Provent 200, otherwise you still get the oily vapor allthourgh the air inlet circuit.
I did it and I very satisfied, no oil vapor deposits on the tubes or intercooler, you can see pic on my blog if you want
Thegippo.wordpress.com Happy Travel
www.thegippo.wordpress.com
Post #365060 16th Oct 2014 8:16pm
sherifsalem
You can check more info in this French vid
http://wp.me/pFe4N-6V Happy Travel
Post #365063 16th Oct 2014 8:20pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Does the Provent allow it to run cleaner? Will it help exhaust smoking and emissions? I've seen them mentioned but don't know too much about them
Post #365100 16th Oct 2014 9:58pm
sherifsalem
What i can confirm to you Lambley is that the circuit is in fact clean now no oil deposits on the tubes from the Turbo to the intercooler , the intercooler itself is clean and finally from Intercooler to Air Inlet manifold.
The provent infact retains these vapors to a very high degree, i purge the filter every 5000-10000 km and you can see liquid oil draining filling a cup.
There is no mistake that those vapors are going to air inlet manifold and together with recirculating gases from EGR would actually be slowly killing your engine performance(i found black thick TAR like in the inlet) in the combustion chamber.
I dont think the filter does anything on emissions or black smoke. Happy Travel
Post #365175 17th Oct 2014 10:13am
Lambley
Ok, thanks, I'll look into fitting one.
Post #365250 17th Oct 2014 4:17pm
sherifsalem
Seeing is believing....
This is what comes out from the crankcase after 5000km in Morocco.. Happy Travel
Post #365445 18th Oct 2014 4:39pm
Page 2 of 2 <12
