Home > Puma (Tdci) > ECU upgrade causing new noise - anybody else experienced it? |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Hi is this noise coming from the engine or your gear box the reason i ask i've got a simler noise coming from my transfer box NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
11th Jun 2010 12:35pm |
niglyn Member Since: 12 Jun 2009 Location: Surrey Posts: 82 |
could be near the gearbox as the sound is barely audiable under the bonnet and most loud in the drivers seat.
I'm wondering if it is connected with the 'scratchy scratchy scratchy' noise heard when turning off the engine, and the new ecu flash is now also operating this valve when the engine goes above idle, thus creating the noise. If LR say what it is & why, I can live with the annoying noise, but not knowing if it is meant to do it or the noise is caused by a faulty part is a problem. |
11th Jun 2010 12:49pm |
Mine only happens when letting of the throttle at 70+ Strange...I'm in on monday for head mechanic to test drive i'll keep you posted NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
11th Jun 2010 2:05pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
That scratchy scratchy noose is the EGR valve self-cleaning (it does five cycles). One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
11th Jun 2010 9:47pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
I've just had my second service done and they updated the ECU at the same time. Now, every time i drive past a wall or go through my local village everybody turns to see what's coming because of the crappy noise it makes when going slow. It's bloody awful. I've had no problems with the engine until now and hope it goes away when i reinstall my BAS tune. I'll do that when they've fitted a new steering box on Monday. 130 crew cab
98 V8 Disco |
12th Jun 2010 12:07am |
