Home > Td5 > Who did unplug the Clutch sensor?
roel
Who did unplug the Clutch sensor on the td5 and what did you do with the connector?
Did you just take it of and left it or did you make a connecting between the contactpoints?
I have my Clutch sensor unplugged and can't say for sure that it helps me getting more power at a start off a hill climb. I understood that the ECU keeps the power back till the clutch is fully released.
I noticed that my Cruise Control stopt working as the sensor breaks the connection when pushing the clutch pedal down, now I connected the contacts off the plug so the ECU thinks I never use the Clutch anymore. Mr. Green
The Cruise Control works again and even stops working if I press the Clutch pedal. Ok the revs go up for a short moment and then the ECU stops the CC.
I didn't test it offroad yet but will I now have full power as soon as I use the right pedal even that the clutch is not completely released? Roel
2003 90 Td5 (2009-now)
Post #341179 27th Jun 2014 12:46pm
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
Applicable to Auto conversion?
Hmm, I would be interested in the result of this... Smile
I converted my Td5 to auto. I just unplugged the clutch switch and taped it up when I removed all that gubbins. Should I have bridged the contacts? (I did ask Ashcrofts, and they just said to tie it up out of the way).
I would be grateful if you could let me know which it should be.
Thanks
Chris Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #341198 27th Jun 2014 2:05pm
Martin
Site Admin
My Td5 retrofit has never run a clutch switch, never noticed a problem or any difference from a factory Td5 Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #341199 27th Jun 2014 2:09pm
Brucey
Well, just had a look at the pedal box that I took off when I did the conversion. The clutch switch "makes" when no pressure in the clutch system. This implies open circuit when clutch depressed. SO...if the ecu gives more power when clutch not depressed, I should short the connector.......I'll have to try and see Very Happy Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #341214 27th Jun 2014 3:26pm
roel
A small fuse (from a disco3) can be adjusted to fit. Mr. Green Roel
Post #341215 27th Jun 2014 3:31pm
Brucey
Good thinking, thanks
BMW R1200GS
BMW F650GS Dakar
Post #341219 27th Jun 2014 3:40pm
jst
i took it off mine, it disables the anti shunt program. in other words it allows you to control engine revs on a gear change rather than making them hang which was meant to make it smoother on the transmission for those that struggle with the concept themselves (ie rushing it)
it made mine more preferable to drive for my style of driving. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #341249 27th Jun 2014 6:24pm
