Home > My Defender > Silver 90 TD5 Build: Re-envisioning a great |
MrB Member Since: 30 Jan 2014 Location: Buckinghamshire Posts: 79 |
This was a project that was influenced between my brother and I so we both had ideas of how we could re-envision a Defender. Naturally the forum was a mixing pot of amazing ideas and resources.
The one definitive idea we both shared though was the want to stay true to the Defender and wider Land Rover range styling. So as I was crazily anxious of doing anything without a plan we hit Photoshop! So we initially were split on a route and were torn between evolving the overall look of a Defender, or trying to mix it up slightly with some DNA of the 'floating roof' design. See our initial thoughts below; Click image to enlarge Click image to enlarge |
24th Jun 2014 7:23pm |
Aside from the quandary regarding the design style and route to progress down, the most apparent thing we felt needed addressing was discovered on our journey back from James French.
Previous to this I had owned a W460 Gelandewagen and my brother's pride and joy is a somewhat modified Disco 1 and to say our new Defender was a little noisy in comparison, would be an understatement. So sound deadening of sorts was going to be our first port of call. So the interior strip out began... not a quick job due to some kind of adhesive under all the carpeting, but if a job is worth doing and all that... Click image to enlarge Last edited by MrB on 3rd Jul 2014 8:20pm. Edited 1 time in total |
24th Jun 2014 7:35pm |
This was the beginning of an obsession...
24th Jun 2014 7:40pm |
And so it continued...
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
24th Jun 2014 7:55pm |
And continued...
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge It must be said this is not the job for someone with OCD as getting the logos all straight became a bit of a crazed obsession!! :roll laugh: |
24th Jun 2014 8:02pm |
Almost there with the tin foil... just shy of a jacket potato baking kitchen!
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
24th Jun 2014 8:09pm |
In all seriousness, sound deadening is a time consuming process and one that you want to only do the once.
However the difference was amazing. Panels were solid to touch, the vehicle felt structurally more sound (which it should do with half a ton of bitumen and tin foil being added!! Lol) and acoustically it was so much quieter. So a job well done for sure. ...but we weren't finished just yet! |
24th Jun 2014 8:13pm |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 |
Great looking defender.
24th Jun 2014 8:18pm |
I'd spent serious and unhealthy amounts of time understanding the science of sound deadening and elected to go the whole hog, so continued with three more stages.
Next came another Dynamat product... Dynaliner. Effectively a very closed cell adhesive foam. Click image to enlarge Click image to enlarge Click image to enlarge |
24th Jun 2014 8:21pm |
Thanks Dave! |
24th Jun 2014 8:22pm |
Top work I haven't got round to doing my roof yet but all the lower half is done
24th Jun 2014 8:28pm |
Then the third stage came in the form of a thick, acoustic cotton – effectively a loose weave cotton material of substantial thickness. Unfortunately we didn't get too many pics of this material, but you can see it being applied to a few panels (light grey material). This was added onto the reverse of all interior panelling and across the roof.
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
ooh i do love a good sound proofing session My 109 thread
my youtube channel |
24th Jun 2014 8:35pm |
Then came the rubber matting which worked to remove transmission and general resonance from the vehicle. Unfortunately we had to do this in a fairly muddy locale so it wasn't super easy to keep clean. We also started an extensive carpeting exercise too throughout the vehicle.
For the rubber matting we used Land Rover's Defender rear load matt (which was excellent value) and the Wright Offroad's acoustic front matt system. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
24th Jun 2014 8:51pm |
