Home > Maintenance & Modifications > Downgrading windows
ZeDefender
Downgrading windows
I've already had some problems with an electric window not opening (at least it was stuck closed).
Thinking of possible problems in future, does anyone know how easy it is to convert electric windows to a winding ones?
Matt Tell someone you love them today because life is short.
Post #339810 22nd Jun 2014 1:46pm
mk1collector
Easier than the other way. Just buy manual mechanisms a winder handle and drill a hole in the door card. Then it's bolt together.
Post #339811 22nd Jun 2014 1:49pm
gilarion
If you do the job place a piece of cardboard on the top of the door frame and with the window shut use some gaffer tape over the cardboard to keep the window closed. Makes the job a lot more easy if you are not trying to keep the window from dropping.
Post #339816 22nd Jun 2014 2:20pm
ZeDefender
Doh - see below... Tell someone you love them today because life is short.
Post #339822 22nd Jun 2014 3:03pm
ZeDefender
Good point - thanks Thumbs Up Tell someone you love them today because life is short.
Post #339823 22nd Jun 2014 3:04pm
gilarion
One other point to note there is one fixing bolt that has an elongated hole, this bolt is used to adjust the window glass so that it it lies vertical in the top channel. loosely tighten all the bolts and finally adjust the glass so that it is vertical at the top then tighten up the adjusting bolt then fully tighten all the other bolts.
Post #339833 22nd Jun 2014 3:24pm
K9F
Matt, I recently fixed Russtybox's electric windows. Two of which had issues. Took me no longer than 30 minutes for the two. Usual culprit are the cables in the door umbilical breaking (as it was in this case). I wouldn't worry about them too much. Sounds to me you've a bad dose of 'Caterhamitis.'
Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #339864 22nd Jun 2014 5:22pm
ZeDefender
Rolling Eyes Smile Tell someone you love them today because life is short.
Post #339891 22nd Jun 2014 7:04pm
