![]() | Home > Puma (Tdci) > Warranty issue - Clutch problem not covered by warranty? |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
[quote="mse"]
I'm only aware of two - the original Ford spec clutch and the current LR spec clutch? www.ralton.co.za |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 555 ![]() ![]() ![]() |
Is that really a rule or just a best practice? Reason I'm asking is because mine was "adjusted", not changed.... |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I think dealers try and take a short cut some times.
My dealer tried the first time to refurbish my original clutch plate with new springs and lining but it didn't last long before they fitted the revised one. (Later another was again fitted) They also repaired my radiator once and then ended up replacing it as it leaked again. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5069 ![]() ![]() ![]() |
Its not best practice, its either in the workshop manual or similar Ill have a very quick look Mike |
a quick 2 second search found:
Mike |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Same here,
When I ask why they don't change the seals, they said me that, under guarantee, they are not allowed to open the steering box, just change it. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Guitarplayer Member Since: 09 Nov 2009 Location: Akersberga Posts: 18 ![]() ![]() ![]() |
Thanks for the info.
I will go back to my dealer to sort out exactly what adjustments they did on my steering box, my 3 year warranty is running out so i must do it asap. Land Rover Defender 110 SX Station Wagon 2007 |
