Home > Maintenance & Modifications > Double Cab Rear Window Runners |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
The back window in our 02' DCPU has seen better days and the glass has started to rattle in it. I had a poke around and it seem that the felt channels that the glass runs in have rotted away, the metalwork all looks fine. I have had a look around and contacted a few suppliers but none of them seem to know anything about the felt runners for the later style window. I believe the older ones were the riveted in type window whereas I think ours is bonded in. The frame is much larger profile than the earlier style which I think matched the rear side windows in 90/110 CSWs.
Has anyone managed to source any felt runners for this style of window? Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
18th Jun 2014 8:46am |
To clarify the rear window is this style:
http://www.keithgott.co.uk/Images/Photos/P...)-big.html It looks a little like the window is riveted in from the inside of the truck (hidden by the trim panels). In which case I can remove the trim to drill out the rivets (which will remain inside the sealed window channel. Looks like it is just a case of sourcing new runners. 02' 110 TD5 Double Cab Rebuild Thread |
18th Jun 2014 3:28pm |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 |
Or....If you want Dave @ Landyglass does a replacement glass that sits in there nicely. It's a non opener tho.. Putting Dreams on Drives at JLR Solihull..
18th Jun 2014 4:39pm |
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 |
?MPS cant find contact info
Anyone help please Andy Defender Td5 XS90 |
18th Jun 2014 7:23pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
Here you go. http://www.mps-trading.co.uk
I've bought a few bits from Simon, top bloke, great service. He also has a 4x4 store on eBay. Let me how you get on as I need some new felt channel for my DCPU. 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
18th Jun 2014 8:16pm |
