![]() | Home > Maintenance & Modifications > rear of 110 |
lyon99 Member Since: 05 Jun 2010 Location: Perthshire Posts: 20 ![]() ![]() ![]() |
I got a dog guard put in mine then i ply lined the sides and put 2 removable shelfs in the first one comes up to wheel arch and the second one goes up to the bottom of the window which i put a mantec window guard on the lining only took 3 hours and cover all plastic surrounds so there no chance of denting in body , i cant put photos on yet but i will post some later on, I can get alot in now 2 chain saws and all my tools for fencing and 2 jack russels and still have more space .
lyon99 |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
![]() Going to put a shelf at the top too, going across the vehicle using the existing fixings ![]() |
Rob, the window trim is a PITA. Along with the new shape wheel box!
Both makes fitting of the MSS stack and stow units more awkward. Believe Kev at Mudstuff is doing an infill panel panel. Give him a ring and prod him along! ![]() Tack, nice ideas! Use Ali or steel 1" square tubing? Is that a Oz tent stretcher or King Goanna chair tucked away on nearside? Brendan |
Devon 4x4 seam to think that the Mantec (Tack) Shelf has ceased production
opps it was nothing I built was it ![]() Brendan, I used 1" steel, and 1.5mm steel perferated sheet. Yep that as King Goanna, dont leave home without it or my stove ![]() ![]() TACK |
yup Mantec will be after you
Boab do a top shelf look http://www.boab.biz/images/Space-Rack%20Factsheet.pdf
Have a wire cage in the top of our 110 overland vehicle which is good ![]() Understand there is now a severe shortage of Goanna and King Goanna stretchers in the UK ![]() Brendan |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
Getting a little OT, but I was in Go Outdoors at the weekend and saw what I thought was a Oz Chair (not the Goanna but the other one!) On closer inspection it was Outwell branded, so it may be worth checking if Outwell do the other types too. http://www.gooutdoors.co.uk/outwell-camper-deluxe-black-p146709 2002 Defender 110 DC |
Whilst that Outwell chair looks similar to the Oztent Kakoda chair that is as far as it goes.
The Outwell chair weighs less then 3.7 kg, costs £40 and no indication of its rating or warranty The Oztent Kakoda chair costs £47, weighs 6.5 kg and is rated at 150 kg and carries a 5 year warranty. Have been looking for alternatives whilst still keeping the spec and build specifications but no luck so far. Suggestions welcomed. OK going OT Brendan |
jimbo23 Member Since: 12 Mar 2010 Location: salisbury Posts: 9 ![]() ![]() |
I found this site while looking for panels for my mates 90, they do panels for 110 utilitys too,
Maybe of some use ![]() www.tge-defendertrims.co.uk |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
Cheers Jimbo been looking out for them to list the utility panels
![]() 55 TD5 110 CSW Special Vehicle |
Great Find Ordered
Still trying to sort the draws out Boab want 1400GBP
