Home > Puma (Tdci) > Idle Jack |
Smurph Member Since: 29 May 2013 Location: Zimbabwe Posts: 27 |
Can anyone tell me how to disable the idle jack? vehicle is 2012, 110.
19th May 2014 1:45pm |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 |
Dont think it is possible to do that
19th May 2014 2:12pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
As a matter of interest, why would you want to?
19th May 2014 2:29pm |
I rather control the revs myself
20th May 2014 8:42am |
Can be done. Simply disconnect plug on top of transfer box.... much better
17th Jun 2014 9:12am |
Phil_D Member Since: 09 May 2014 Location: Perthshire Posts: 25 |
Smurph, which plug did you disconnect?
Phil. |
17th Jun 2014 1:07pm |
Thanks, I'll experiment with that!
Phil. |
18th Jun 2014 7:50am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I don't understand why you want to do it as I think it's the only improvement from an td5.
But yes by disconnecting the plug the ecu doesn't know you are in low gear so will not use the anti stall mode. You can't do this anymore then: https://www.youtube.com/watch?v=0jhuKLrjJLg&feature=related just after 1 minute Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
18th Jun 2014 9:25am |
It won't affect the anti-stall at all, just the idle jack, which is a totally different and independent thing.
Idle jack is a safety feature to prevent you coming a cropper on very steep descents, where the very low 1st or reverse gear will cause loss of traction. I have to admit I still don't understand why anyone would want to disable it, but the method described above will do just that. |
18th Jun 2014 5:54pm |
